5.9 Magnum FI cam upgrade
Good to know, thanks. Ive been doing some research and it looks like the manual flywheel for the 5.9 Magnum with FI is a hard and expensive item to come by. It's got me wondering if the 5.2 Magnum would be a better choice; any thoughts? I've got a good AX-15 5 speed from a V8 Dakota that Im going to use.
Agreed on the LSA of the cam. Stupid PCM goes nuts if it's too lumpy, and gives random misfire codes.
i gotZ a lumpy cam in the 408 and doesnt set misfire codes,
[ame="http://i420.photobucket.com/albums/pp282/360dakota/01%20dak/P1010016.mp4"]
[/ame]
If you balance the 360 when you build it, then you can use any flywheel and harmonic balancer you want.
Although, you should be able to buy a Dakota flywheel from a 98 right up to 03, if I remember right.
Yeah, I plan on just finding a good running engine and using it as is other than possibly a cam change. Doesnt the 5.9 have a dedicated flywheel?
I want to say yes, but I don't know the manual transmission setups very well. I know the automatics have balance weights on the flex plate, and a different harmonic balancer than the 5.2 motors do.
