5.9 magnum swap
No worries about hijacking it's all gd info being put out and on topic sooooo hi Jack away. Lol
that answer would require a lot of info on engine build and cam but in general, TB SHOULD make close to MPFI but MPFI should have better low end torque and better throttle response.
No worries about hijacking as long as its on topic. lots of good info
So just finished freshing up a 99 5.9 to drop into my 65 dart. leaving it efi and obd2. Ive done numerous obd1 swaps into jeeps and been studying the wiring for the obd2 so I'm confident I can accomplish this. picked up ac compressor tonight wich was last eng component needed so did a trial fit of the shaker hood scoop base meant for a 70 challenger and best thing is it clears everything on the magnum engine :blob: finish getting engine compasrtment finished and in paint hopefully be dropping it in near end of month:cheers:
Hey, just curious why you are not using the stock AC compressor from donor? Doing a similar swap, any reason not to use the original compressor? Thanks in advance for your thoughts!
