would like to know who is running one of these in their a body, what kind of specs, and what kind of performance you have gotton from it.
I have read about what is required to swap one over in place of a LA engine and think I have that covered.
here is the idea that I am playing with.
use the stock short block from a junk yard engine. take it apart and maybe put rings and bearings in it, along with some new freeze plugs, oil pump, and timing chain.
order a set of EQ or RHS heads to replace the stock magnums that are most likely going to have cracks anyway. I would still use the factory rockers. on the cam I would go with a little better grind from comp.
use a thinner .028" head gasket to raise compression to around 9.5-1. top it off with a RPM Air Gap intake and a 750 cfm Holley.
anyone have a similar combo?
while its not an A-body, I have came across an Aspen Wagon that is cherry and have always wanted to do a street bruiser build on one. that would be where the magnum would end up. just trying to build a hot little street motor on the cheap instead of going through the full expense that I normally do with my engines.
thanks for any replies.
