ronw
Thinking of putting a truck V8 2000 or newer 5 speed top loader in back of a 1968 318 eng. Will this combo work? Thanks Ron
were there any model cars that had a 5 speed that would be suited better for this swap with less work?Another matter to consider....
Truck transmissions are often suited for load hauling, not rapid acceleration. The gearing will be different from a transmission designed for a car.
No.were there any model cars that had a 5 speed that would be suited better for this swap with less work?
thank you for the info.ronNo.
The only "bolt in" 5 speed would be the aftermarket Passon A855 unit, but there were too many quality control issues at the time, a huge backlog on orders, and I'm not even sure that it's being offered anymore.
Many "buyer beware" posts on this site, like this one:
A855 - 5 Speed
Another option would be a T-5 (WC being the strongest of the bunch) out of a Mustang, using the Gill Welding adapter (I know it's listed as a slant 6 adapter, but the bellhousing to transmission bolt patterns are the same).
T-5 Bellhousing Adapter Plate For Slant Six | gillwelding
Just be aware that there are many different versions of the T-5, most of which would only be suited to a lower-output engine. A T-5 still requires tunnel mods, but nothing too extensive. The T-5WC is the strongest of the bunch and can stand up to some fair abuse.
Silver Sport also offers a kit... Inside Silver Sport Transmissions' All-New T-5 Kit For Mopar A-Bodies - Mopar Connection Magazine | A comprehensive daily resource for Mopar enthusiast news, features and the latest Mopar tech
I know Kiesler (defunct, now SST) used to offer a redrilling service to the T-5 pattern on an 833OD bell, but not much info out there on that out there or what it takes to complete the swap.
BTW, you still haven't mentioned what you intend to put this in?
This is the exact master/slave cylinder setup I used in my ax15 swap. And like you said, the pushrod length wasn’t correct, so I cut out a section of the rod, threaded the ends of the cut rods and put it back together with a coupling nut to give me adjustability.note also his views on the cheap and appropriately angled 1986 chevy S10 clutch master..
Its the OEM part that appears to have been copied by all to make their expensive bolt on cluctch master for mopars.
seemingly has the perfect angle of dangle to fit with the contour of the firewall..and just needs a new hole drilled for the studs
these a $25 on rock auto if its too long in the pushrod i'm sure a new rod end could be grafted on
Dave
This can be worked around. For example, the ax-15 ratios in my Duster areAnother matter to consider....
1st - 3.83
2nd - 2.33
3rd - 1.44
4th - 1.00
5th - .79
Running those ratios with 2.76 rear gears gives you almost IDENTICAL acceleration in the first three gears as a 904 with 4.10’s, plus gives you 2 more gears. And a .79 overdrive coupled with 2.76’s makes for pretty awesome highway cruising!
There are a couple of guys running an AX15.
I know @dartslantsix is one - David Belau
@75slant6 is another.
An R154/MA5/AR5 could be swapped into the same place and gives better ratios. And the MA5 survived Rocky Mountain Race Week in a C10 behind a 392.
I have owned a 2004 Chevrolet Colorado 3.5 I-5 with an AR5 in it for almost 17 years, have driven it 100k miles, I do like the truck, but why anyone would go through the effort to swap that transmission into a performance car is beyond me. It has a 220hp, 6300 rpm capable engine in front of it and its a ZQ8 (lowered, 2wd) so you can really rip on it. Hasn't broken but that's not really selling me as a performance transmission. The gear ratios are too low in 1st for a V8 car unless you have a super tall gear. 3.74/2.26/1.31/1/.73. My truck has a 3.42 rear end and similar size tires and the 5cyl will spin without doing anything crazy with the clutch, even with 245/45-17's (I now went back to the stock 235/50-17).
Yes, you can shift it at 6200 rpm, I have done it many times, but only really fast from 1-2, and you can get good rubber with the I5 even. 3rd gear syncro isn't that good so it will grind sometimes and the shifter is kinda clunky. Shifting 3-4 is clunky, sounds like a box of rocks with the clutch out at idle, even though it uses gear oil and not ATF. The clutch action on the truck is great but its only a 9.5" hydraulic clutch.
If you're going to spend time fabbing, going to hydraulic clutch, I would still tell you to save up for a TKX or T56 Magnum. The T56 magnum in my Duster is an absolute joy compared to the AR5 or an A-833 for that matter.
Yup. 20 year old me on a super small budget wasn’t gonna be able to afford a T56 swap, so AX15 it was… that’s been 9 years and 18,000 miles ago and she’s still doing GREAT behind my stock 5.9.No doubt it is far from the ideal trans, but if someone where to want to keep the costs down and ran a 2.XX gear, doesn't seem like a bad option.
Worst case, swap in an AX15/AR5/MA5 and save up for an R154 down the road.
That said, I bought a T56 Magnum last winter and plan to start on my G3/T56 swap soon. So no disagreement from me.
If you are happy with a large rpm drop between gears, go for it.
A first gear ratio of 3.83 to 1 is worthless in a car unless you’re just cruising. The 1.5 ratio drop to second gear is close to the 833 overdrive. If your car had any performance cam in it, you either have to short shift from 1 to 2 or have acceleration in 2nd be sluggish when you run it to 5500-6000 in first.
It is your decision. It is best to make them with all the information you can collect to know what downsides you’ll encounter
2001 Mustang GT TR3650 | A833 OD | AX15 | A833 | A833 | R154 | TKO-500 | A833 /6 | A833 HOD | Colorado MA5 | Solstice AR5 | |
1st | 3.38 | 3.09 | 3.83 | 2.47 | 2.66 | 3.25 | 3.27 | 3.09 | 2.66 | 3.753 | 3.753 |
2nd | 2 | 1.67 | 2.33 | 1.77 | 1.91 | 1.95 | 1.98 | 1.92 | 1.59 | 2.26 | 2.26 |
3rd | 1.32 | 1 | 1.44 | 1.34 | 1.39 | 1.3 | 1.34 | 1.4 | 1 | 1.37 | 1.51 |
4th | 1 | 0.73 | 1 | 1 | 1 | 1 | 1 | 1 | 0.8 | 1 | 1 |
5th | 0.67 | 0.79 | 0.75 | 0.68 | 0.729 | 0.729 | |||||
1-2 drop | 40.83% | 45.95% | 39.16% | 28.34% | 28.20% | 40.00% | 39.45% | 37.86% | 40.23% | 39.78% | 39.78% |
2-3 drop | 34.00% | 40.12% | 38.20% | 24.29% | 27.23% | 33.33% | 32.32% | 27.08% | 37.11% | 39.38% | 33.19% |
3-4 drop | 24.24% | 27.00% | 30.56% | 25.37% | 28.06% | 23.08% | 25.37% | 28.57% | 20.00% | 27.01% | 33.77% |
4-5 drop | 33.00% | FALSE | 21.00% | FALSE | FALSE | 25.00% | 32.00% | FALSE | FALSE | 27.10% | 27.10% |
Oh it works for me, but remember its a 3600 lb truck with 225 lb-ft of torque.
A833 OD | AX15 | A833 | TKO-500 | A833 HOD | |
1st | 3.09 | 3.83 | 2.66 | 3.27 | 2.66 |
2nd | 1.67 | 2.33 | 1.91 | 1.98 | 1.59 |
3rd | 1 | 1.44 | 1.39 | 1.34 | 1 |
4th | 0.73 | 1 | 1 | 1 | 0.8 |
5th | 0.79 | 0.68 | |||
1-2 drop | 45.95% | 39.16% | 28.20% | 39.45% | 40.23% |
2-3 drop | 40.12% | 38.20% | 27.23% | 32.32% | 37.11% |
3-4 drop | 27.00% | 30.56% | 28.06% | 25.37% | 20.00% |
4-5 drop | FALSE | 21.00% | FALSE | 32.00% | FALSE |
Final Drive | 3.21 | 2.71 | 3.91 | 3.21 | 3.91 |
Peak Tq | 362 | 362 | 362 | 362 | 362 |
1st | 3591 | 3757 | 3765 | 3800 | 3765 |
2nd | 1941 | 2286 | 2703 | 2301 | 2251 |
3rd | 1162 | 1413 | 1967 | 1557 | 1415 |
4th | 848 | 981 | 1415 | 1162 | 1132 |
5th | 0 | 775 | 0 | 790 | 0 |
Correct, I ran 3.23 gears initially and 1st gear was worthless outside of taking off on a hill, after swapping to 2.76’s I shift it like any other 5 speed, aside from when I’m auto crossing, then I can run faster times if I start off in 2nd. Don’t spin as easily off the line and don’t need to make the 1-2 shift. I then run the whole course in 2nd.Maybe it would be better to say that it sounds like the deeper final drive makes the transmission feel very truck like to you.
Seems like @75slant6 ran a deeper final drive with his AX15 when he first did the swap and then dropped down to a 2.76 final drive.
I’ve gotta disagree with you on the 3.83 gear being worthless in a car. Like Dion said, check out my early post (post #10), you simply need to run the appropriate rear gears.If you are happy with a large rpm drop between gears, go for it.
I read what you posted. It is wrong if you have a cam much bigger than stock.I’ve gotta disagree with you on the 3.83 gear being worthless in a car. Like Dion said, check out my early post (post #10), you simply need to run the appropriate rear gears.
I still don’t see the issue. If a 904 with 4.10’s works behind a built engine with a bigger cam, then this will work also.I read what you posted. It is wrong if you have a cam much bigger than stock.
If you have a stock engine and use this transmission and a 2.76 gear, you'll still have the huge rpm drop but it won't matter as much.
What kind of dude is happy with a stock engine??
