[SOLD] 500ci Stroker Engine Kit- Complete
scooby67
CT
500“ stroker engine kit purchased from PAW in 2006.
Came completely machined and balanced ready for assembly.
440 block .060 over (4-14-1973)
Forged steel 4.150” stroker crank
PAW 6.760” connecting rods
Ross flat top pistons with valve relief
Edelbrock 60189 assembled heads with 88cc chambers
Pioneer 1.5 ratio roller rockers
PAW pushrods
PAW lifters
Crane Powermax hydraulic cam 644561 (duration at 050 lift 232/242, lift .504int/.528exh)
Summit Racing timing set
Clevite 77 bearings
ARP head bolts and studs
High volume oil pump
Complete Fel-Pro gasket set
All paperwork with machining specs is included.
$7000 firm pick up only.
