505 stroker motor
jamey
PA
This is my 505 440 based stroker motor. I sold the body the engine and trans were in, and won't have another car on the road for a couple of years probably. I don't want to store this and I want to build a hemi. The engine has less than 700 miles on it.
1975 440 block .030, decked, oil mods, align honed with bcr aluminum mains and arp studs.
K1 4.25 crank, compstar 6.8 h-beam rods, diamond flat tops 11.2 cr. all balanced
edelbrock rpm heads cnc ported by modern cylinder heads with pac endurance springs.
comp solid roller 260 ' @ .050 and 650 lift with isky red zone roller lifters, crane push rods and comp pro magnum roller rockers bushed by ras.
edelbrock victor intake, milodon deep pan.
I have most of the receipts for this build and used quality parts. I have a reference for another engine I sold to someone on another mopar forum if needed. The engine is on my engine stand in NW, PA and I will ship this if needed. I'm keeping the distributor, carb spacer and motor mounts.
$6500 obo
I'll post pics later
