ValiantS
These are the core parts to build a 511" low-deck. 1)Baked 1971 '230' thick main web block. 2)Used but fresh grind Ohio 4.250" crank std. B main and 2.2 rod. 3)Used JE 4.375" pistons and pins. 4)Used Eagle 6.535 H-beam with new bolts OR Known-used GRP 6.535 HD 'pro' rod. ($1600. FIRM) I will not seperate.
