[FOR SALE] 511" B parts
ValiantS
Shelby, Michigan
These are the core parts to build a 511" low-deck. 1)Baked 1971 '230' thick main web block. 2)Used but fresh grind Ohio 4.250" crank std. B main and 2.2 rod. 3)Used JE 4.375" pistons and pins. 4)Used Eagle 6.535 H-beam with new bolts OR Known-used GRP 6.535 HD 'pro' rod. ($1600. FIRM) Can ship, can seperate.
Might be interested in this and your 360 block for sale if you respond. Your inbox is full.
Thank you, still getting adjusted to this site. (Remember the rules here sir, no phone numbers in public forums, for your own safty.)
These are still available and will separate the pistons for $300 credit. Inbox is small so I've not been able to manage correspondence well. I'm trying to be respectful of response and distance to expedite room in my shop. Thanks to all, Sean
Myt be interested
Compression distance on pistons ?
Width on con rods
