Todays call was to Chris Paget at Bullet cams. Currently out of cores for the wide seperation
However:
Here is his reccomendations
248/254@50
636/636 lift
114 lobe seperation
Springs 230-250 seat and 550 open pressure.
Sounded like he loved the Holley sniper efi
Could be, but good things happen when using matched parts, the whole nine yards.I think TF has one of the most generous dynos on the planet....
TF claim with the above 243/247 @ 050 cam, a 440 made 620 hp.....
I just got this cam done fron Schneider
512 400 block 10.5:1 trick flow 270 fi tech efi , txk5 3.77
I have the 1200 horse kit from fi tech. I understand it will be a little hard to run on that type of Cam but I'm gonna be running blended e 85 and 91 octane since the motor won't produce a lot of vacuum I should be able to be fine
