512 Re-Install into 1967 Dart GT Convertible from the Bottom (photo's)
"Dart67"
Jessieville, Arkansas
Here are photos of my"Home-Brewed" Engine and Transmission Cradle.
As well as the installation sequence of the engine and transmission assembly from the bottom.
The body of the car is lifted using the "Home-Brewed" engine crane. Then rolling the cradle, engine and transmission under the car.
The slowly lower the body over the assembly and bolt the front cross member and trans mission mounts into place.
This is the ONLY way that I will ever install a Big Block or Small Bloc
MOPAR engine into a A-Body MOPAR.
Very nice . What ignition and fuel system are you using.
"Home-Brewed" EFI and Coil Near Plug using F.A.S.T XFI 2.0 and F.A.S.T XIM with "Home-Brewed" wiring harness from trunk mounted battery to under dash mounted ECU's and engine bay. If I remember correctly 96 wires.
I need one of those soon. any chance you could provide details? Thank You.
