[FOR SALE] 513s with a spool
oldkimmer
Kindersley, Saskatchewan,
Older case but I believe it to be a 742 case. Schaefer gears. Pinion has 8 teeth, crown has 41. It has a block in the middle of the spool that slides back and forth so u can run tapered bearings. 35 spline spool. Don’t see any markings on it at all. The yoke is 2 5/8s measuring on the inside. I got this on trade and don’t know anything about it. $650.00 usd plus shipping. Thanks. Kim
1-3/4" large stem pinion (aka. '742')
Carrier casting numbers: 1634985 (1957-1964), 2070742 (~1961-1969).
