526 Hemi For Sale
Hemirunner
Down South
Rating - 0%
0   0   0
For Sale: 526 Hemi Engine, Mopar Performance non-World, cast iron water block. 4.310” bore. Sonic testing shows it should go 4.400” if need be. RPM 4340 forged 4.500 stroke crank, RPM 7.100” H-beam connecting rods, Diamond forged 2618 alloy pistons, 12:1 compression ratio, gas ported, .043 steel top/.043 napier second, 3mm oil ring. Clevite bearings, comp custom roller cam, (insert specs), comp 829-16 solid roller lifters, bronze bushed lifter bores, smith brothers heavy duty pushrods, Pro-Gear double roller timing set, Comp Torrington thrust button, Milodon 8 quart pan and pickup, high volume oil pump, Indy 426-1 cylinder heads, Indy roller rockers, Indy black wrinkle plain cast valve covers, Indy dominator intake manifold, MSD pro-billet distributor. Just finishing assembly now and will be on the dyno in the next few weeks. $17,500.Illinois.
any dyno numbers?
Haven't had it on the dyno yet. With little to no interest in it, I have been working on other projects with higher priority. I still need to work over the intake manifold and get pushrods ordered for this one.
