Bakerlite
- Joined
- Nov 12, 2007
- Messages
- 6,431
- Reaction score
- 3,327
I'm still waiting for Hemi446 to explain himself...Sounds like a crock to me..
I was merely asking if that if you have 2 Hemi blocks, one of the original 426, from Map Mopar in the 60's early 70's, and if you can take that factory OEM valve covers off that 426, and bolt them right to a 528 Ma Mopar factory OEM head......Merely are all the valve covers "interchangeable" from one Hemi 426, all the way up to the 540 Hemi that was also Map Mopar OEM motor?
I'm not sure if I'm asking the question right to the answer I'm trying to find out,.....
As soon as I find the spec sheets from Stage 5 I will be happy to post them for you. These heads are advertised to flow 10% more than stock heads. I built a 426 engine that was totally stock down to the carbs and the distributor but it was recurved customer had it dyno'ed a 490 ft lbs of torque and 531 hp. it was the original engine from his 68 Road Runner. I built the engine in my car 15 years ago and a lot of that stuff is in folder some were. I don't have any thing to prove to anyone I built this car for me. If way one want to go for a ride or see the car just let me know
without a doubt....yes
the heads have nothing to do with the bore / stroke cubic inch displacement.
There's no secret HemiDenny, because those numbers never happened with that cam.
