Ken Scarborough
I I purchased a stand alone system from Swap spealties, a big mistake. It doesn't work I have replaced most all sensors. I have 55-60 psi of fuel pressure.while trying to start I have power to my coils and injectors . I removed the spark plugs from#1 to see if it was firing and the engine started and sat and idled and started to smooth itself out. When I replaced the plugs it will not start just spin over.we thought that maybe the engine wasn't spinning fast enough to work the crank sensor. I replaced the crank sensor and made sure the battery was hot and jumped a hot battery with it no change.
I bought a Mopar wiring thumb drive and traced the wiring #1&5 on the throttle body was crossed and a wire. From the pedal had a break between the pedal and c2).
I'm in search of and exorcist or devine intervention.
I was told yesterday that it will not start unless I program the pedal.
How do I program the pedal?
It's a 2012 5.7 out of a charger with a 2008 545rfe out of a ram 1500
Any help is appreciated
Thanks Ken
Thanks Ken
