Garrett Ellison Amateur driver on public roadway, do not imitate.. FABO Gold Member Joined Jan 1, 2018 Messages 5,590 Reaction score 5,164 Location Southwest VA Sep 21, 2020 #26 I did find out that my friend used a 1998 Ford Explorer rear axle and drive shaft as a direct bolt in. The only change needed was a conversion u joint to mount the Plymouth transmission companion flange to the Explorer drive shaft.
