Hey guys,
This seems like a crazy good deal to me so I am Passing it on. I came across it on this goofy alibaba site.
supposedly a good running, 6.4L pulled from a wreck. Here is the info the guy gave me, and a link to the page. If someone buys it please reply in the thread. thanks
http://us117362805.fm.alibaba.com/p...te_Drop_In_Engine_Assembly_Mopar_Hot_Rod.html
they ship from the US. Gave me a price of 2,200 including freight to OH
my chat transcript with the seller
i assume the 6.4 hemi is out of a wrecked car?
us117362805 (2015-02-24 11:11:04): Yes
us104193990 (2015-02-24 11:11:26):any idea if it sustained damage, or what the mileage was?
us117362805 (2015-02-24 11:12:29):it didnt sustain damage
us117362805 (2015-02-24 11:12:47):in perfect condition
us104193990 (2015-02-24 11:13:48):do you know if it was behind a manual or an automatic?
us117362805 (2015-02-24 11:14:22):it was behind an authomatic
us104193990 (2015-02-24 11:14:35):year and mileage?
us104193990 (2015-02-24 11:14:57):and does it come with anything other than the engine? any wiring or computer?
us117362805 (2015-02-24 11:17:12):it only comes with the engine and wiring, no computer
PART # 5037400IA NEW GENUINE OEM MOPAR COMPLETE HEMI ENGINE ASSEMBLY!!!! PERFECT FOR AN OLD SCHOOL HOT ROD OR STREET ROD, COMPLETE FROM OIL PAN TO INTAKE, THROTTLE BODY, INJECTORS, WIRING HARNESS ETC Bore x Stroke 4.09 x 3.72 (103.9 x 94.5) Valve System Pushrod-operated overhead valves, 16 valves with sodium-filled exhaust valves and hollow stem intake valves, 16 conventional hydraulic lifters, all with roller tips Fuel Injection Sequential, multi-port, electronic Construction Deep-skirt cast-iron block with cross-bolted main bearing caps, aluminum alloy heads with hemispherical combustion chambers Compression Ratio 10.9:1 Power (estimated SAE net) 470 hp (351 kW) at 6,000 rpm Torque (estimated SAE net) 470 lb.-ft. (637 N?m) at 4,300 rpm Max Engine Speed 6,400 rpm (recommended) Fuel Requirement Premium 91 octane (R+M)/2 recommended Oil Capacity, qt. (L) 7 (6.6)
