Moparparts
FOR SALE: Original Flywheel for a 6 cylinder. Has 2.16 crank register for 68 and up. Threaded holes are good and it is not heat cracked, but has grooves on the disc use area, and the ring gear would need replaced, or possibly turned around. Not sure if this can be turned or could possibly be used on a run stand. $20 plus shipping from Pa 17086. PM if interested.
