/6 p/s pump to 318?
mycuda
Chicago/ Metro
Hi,
Doing /6 to 318 swap. Can /6 p/s pump be used on 318?
is it a special bracket? Can other brackets be modified?
Thanx in advance. Dave
Brackets, pulleys, all different for the 3 or more different pumps and applications.
Even moving a pump from one LA to another gets complicated.
Start at cast iron or aluminum water pump on the LA. Seek accessories for that.
I've done this twice in two A-bodies. I just used the brackets from an LA small block and it worked for me.
brackets, pulley and much more are different, cheapest is to get a small block pump off of a member on here that has everything on it already and ready to bolt on
