IDK, what does the book say.
I give up.
Contact Jadaharabi
He's got all the answers.
I give up.
Contact Jadaharabi
What I believe you are indicating is I should be backing out the center carb idle to closed throttle, adjust the rods for closed outboards, then bring up the idle with the center.
Is this correct?
What hose was off exactly & where did You attach it exactly? The outboard vacuum pots should "tee" together and attach to the venturi port on the center carb. If say, theYou know, your right, theres no metering plate on the F/R carbs, so nothing for the power valve to screw into. I really should have thought this through, instead of freaking out and jumping online...
Thanks
