Finally got back to work on it. Wanted to adjust the valves but stuff came up.
Was checking timing.....it started acting weird it was all over the place, 10* 12* at idle, at about 2K rpm it was about 30*.
Daughter reved it really high and when I went to check it again at idle it was reading 20*......what the heck?
Could this be a bad harmonic balancer? I have heard of them slipping and giving bad timing readings. What is the best way to check, pull #1 plug and check TDC and make sure the pully is lined up? Thanks all, Matt
