169dart4y
I'm done with my 318 swap and I'm thinking there is a problem with the neutral safety switch?
The three wires , middle brown strait to the starter relay , the out side black wire goes to the bulk head /wiper bulk head. The third wire is the other out side wire on the three prong switch , it also goes to the wiper bulk head next to the other black wire . this one is black with a white stripe.
This is the way my 69 dart with a slant six was wired when I took it apart.It also had a 904 auto trans . The 904 trans that I'm using with the 318 is a 74 dart swinger . I tried to adjust the linkage , tried neutral , tried drive , everything else in the car seems to work correct.
I'm using the 69 wiring harness and added the 74 v 8 electronic ignition to the slant six harness .
