[SOLD] /6 truck bellhousing
Princess Valiant
A.K.A. Rainy Day Auto
Colorado
I have a bellhousing from a 70 D 100 with a slant.
No cracks and the motor mounts are included.
$75. Plus shipping from 81005
Still available
Adding a comment so folks know what that bell housing can do. And I believe that I have this correct.
All other stock slant six bell housings will only accept a 122 tooth flywheel. That severely limits the available clutch and pressure plate packages.
The slant six NP 435 flywheel housing will accept a 130 tooth flywheel. The 130 tooth flywheel is used on the small block Mopar so there is a huge assortment of performance clutches available. But nothing is really free because the NP 435 transmission is truly a truck transmission and is not performance oriented. But if there was a way to get an a833 mounted to that bell housing, that could be a sweet package.
All that is true except the 130 tooth flywheel part. It's actually a 143 tooth flywheel for the 11 inch clutch. It's really heavy duty.
I have one just like it for a small block I will swap straight across.
WTH!!! are you reading my mind, I need one for a SB
How do we do this, i can get mine shipped in the next couple days, maybe tomorrow but no promise on that because i have to find a box
Lemmie go lay my hand on it. brb
Here it is. You showed me yours now I'm showin you mine. Don't tell Kitty though. LOL It'll need cleanin up cause the aluminum has a little corrosion on it, but it's in good shape.
Nice!! Good looking parts you have there lol
Is there a casting numero ?
There's a piece of one, but I cannot make it out. It doesn't have big "holes" for the casting number like the one you have. You can see the small holes and it's in one of those but I can't make the whole thing out. If you really just gotta have it, I'll go back out with a magnifying glass and see if I can read it for you.
ok, don't matter, it looks Great.
PM me your address and i will get on this first thing in A.M.
Oh and that's not a hole in the top....well I mean, it is, but it's a factory hole for using a timing light to hit the flywheel on a truck. That's how some of them checked timing.
Mark this thread sold if indeed its gone to RRR in trade.
I believe we've reached a deal on it, Mike. I'm sure she'll respond in her waking hours. Not everybody's a vampire like I am . lol
