/6 with A.C.
justme
Boynton Beach Fla
Does any one have any pictures of a 66 valiant with A.C. with a /6? I want to see the pullys and the engine compartment please !!
This is a 74 duster but you can use the same brackets.
Should have an add on pulley on the rear of the damper and a 2 groove water pump pulley and of course the ac compressor with a adjuster pulley for the belt.
…if you move the battery to the trunk, yes. If you leave the battery in the stock location, no, you can't. The later bracket puts the compressor further over to the left side, where its left cylinder head tries to occupy the same space as the battery in a pre-'67 A-body.
