What column are you looking for ? The 1960 used a different gear box ,The 1960 and 1961 stick cars had the shifter on the floor .The 1962 had the stick lever on the column .Anyway I have a 1961 valiant parts car it is a automatic trans car it is a standard steering car if this helps let me know.
Will help with your search. As a 62 valiant owner I know how difficult finding parts may be. Good luck
the biggest difference is Power steering Vs Non/PS oneWanted a 1962 Plymouth Valiant standard shift steering column. Must be complete. Do not need the steering wheel or steering shaft. I think '60-'62 the same. Send photo if possible. Thanks
