Dartnewbie
Former Dart owner
- Joined
- Nov 11, 2008
- Messages
- 407
- Reaction score
- 0
According to my manual, to set the kickdown linkage, disconnect the ball connector at the bellcrank on the top. I then loosen the slide on the linkage by the kickdown lever and push the lever all the way forward and tighten the slide back up. I then adjust the arm to the upper bellcrank ball connector with the throttle at idle. Does this sound right?
