tdart
Active Member
got a 63 fury i want to put a 318 la engine in it and 904 trans what mounts do i use on engine?what tranny crossmember and mount and oil pan?
... A-bodies use the rear sump oil pan ...
Thanks guy's, ok i am using LA 318 so center sump B body pan and pick up, stock not deep pan correct?i got poly318 block mount,s but no rubber so which rubber mounts do i get,and no this wasn,t a 6 k frame.
This 63 fury is a B/Body so i should be using b/body oil pan?As far as mounts that's what im not sure of 318 big block to 318 small block. do i use 318 LA block mounts with 63 318 rubber mounts and do you use newer trany rubber mount,i got welder not a big deal but id rather just bolt stuff on tired of fabing stuff.
........ 318 big block to 318 small block. .
came out of 74 charger
