nkaust
Member
Whats up guys new here, i have a 63 valiant signet 200. my issues are, no marker lights in the front, no driver side turn signal, no passenger side indicator light?
both rear turn, brakes, running lights work, headlights work, dashlights work if you fiddle with the dimmer a little. passenger side front turn signal works, driver side indicator light works.
i checked the voltage at the driverside front marker light and and i was getting between .2 and .5 volts with multimeter negative hooked to the battery. i replaced the bulb, checked the plug connection at the fender and it looked decent, check the bulb socket and it was clean.
any ideas, much appreciated
