Rapid Robert
excellent OE condition except the inner stranded cable has been replaced by a PO & the front OE "folded tab" with the two holes that slips on the horizontle carb throttle pin had been replaced with an eyelet and the rear end of the cable has an adjustable "clamp" instead of the OE mini ball. works fine & likely a person could pirate an OE cable of the correct length from any OE app & swap it in if desired. $99+ the ride. Postal MO or PP + their fee. cable on right is OE and mine is to the left EDIT Also included is the OE rectangular plate tapered on one end that bolts on the front of the firewall as a stiffener MORE EDIT lets do $79+ the ride
