robjkc
I'm looking at fixing the gas gauge on my 64 Dart. It currently doesn't register anything.
I looked behind the dash and noticed that there was a black wire secured by a nut to one of the terminals but the other terminal didn't have a connector going to it and was missing the securing nut. Here's a picture of the back of a 64 instrument cluster for reference.
I found a lose red wire but it wasn't the type that could be secured by a nut (sorry for my non-technical terminology). I thought I would just stick it on the end of the terminal to see what happened and the gas gauge went all the way to full when the car wasn't running. I would have to get a different connector for the red wire to secure it under a nut on the terminal, but I'm not even sure if this is the correct wire since it was a different type of connector.
I'm not really sure what is going on so I thought I would ask and see if anyone had any ideas.
Also, I noticed I was missing a bulb socket to my oil light. I stole the bright light indicator socket and tried it in the oil light but the oil light does not come on. I'm thinking I'll need to replace the oil pressure indicator switch on the engine.
Thanks for the help!!
