realpank
Active Member
I am stripping/sanding my 64' Dart GT and having a hard time removing the retainer clips that hold on the stainless trim on rocker panels(below the doors).
These clips are 1/2" square and have a retention pin in the centre that gets pushed in to lock them in place. Problem is once pin is pushed in(to un-lock) they fall into the rocker panel and cannot be retrieved.
Is there a better method of removing them so the whole clip can be saved? If not is there a source to buy these new?
Same with the small clips that hold the trim along the tops of the door edge. Have been able to salvage many of these, due to rear access, but some were rotten.
Thanks in advance for your help.
Chris
Chris
