64 dart SB car...727 ?????
barbee6043
barbee 6043
Shepherd, Texas ( SE Tx)
having TROUBLE FINDING ( ANYWHERE CLOSE!), a cable operated short shaft SB A body 904....... would will a lomg tailshaft 727 fit in the tunnel?? I am sure the trans crossmember mount will not be right for one thing.... its a pushbutton car . I have found the SB longtailshaft 727 to use.... thanks
mount should be fine...driveshaft needs to be shortened obv...usually all that is required is to bend the floor to firewall pinchweld over or cut grind etc
