[FOR SALE] 64 or 65 barracuda. not sure
red cuda
water valley,mississippi
Rating - 0%
0   0   0
have a near complete car , that is going to be parted out
let me know what you need
has v8 with pushbutton transmiision
PM sent ..How much for the steering wheel ? and V8 emblems ?
Bill Dedman (A member here) needs the head light rings !! we are both in Arkansas
pins have some tip corrosion, but i think they would work fine, has enough material for a nut easily. they were tight on the fender.
Do you have the plastic pieces on the interior for the back window curve? what shape are the turn signal lenses in? can you snap some pics of those. I'm sure the drivers side taillight is all pitted up.
pics
If you still have the car available and if you have any of these items:
set of four armrests, the flasher switch if applicable, locking gas cap with key, and the trunk prop rod. Thanks!
