64 valiant 4 speed conversion questions.
Got what i thought was a good deal so I picked up this rebuilt shifter and rods to use. handle may or may not work for me, will find out once everything is bolted up.
Since I already have a lakewood scattershield I'll just use it. So now just basically need to buy a clutch fork, flywheel and clutch kit and some boots.
4-speed I have is out of a 69 A-body non OD. coming down from Oregon after christmas.
I'm not sure the Lakewood will work in an early A. I have heard that an Ansen Blowproof fits. I know a 71 340 bellhousing works. Looking at your rods, they look like they would work with 2298 mounting plate. If you have the mounting plate with the 69 tranny, try it. The reverse rod looks goofy. Good luck.
Thanks. Yes I need to test fit it ALL once my brother brings the 4 speed down from Oregon. If the Bell doesn't fit, then I'll hunt for a stock one that will. Have the Mopar Spring Fling on April 18th that will hopefully provide!
