So I for the most part fixed the exhaust manifold and intake manifold leaks on my 65 Valiant 170. It still leaks in the same spot where the two manifold bolt together eventhough I gooped it up with Copper RTV. Maybe it wasn't fully cured yet but it is a lot quieter. It starts super easy even after it's been sitting for 3 weeks. One pump of the gas and one turn of the key and it fires right up and stays running. It's got good power if you get into it gradually but if you stomp all the way to the floor it will pop out the carb and bog but it didn't stall. I put a remanufactured carb on there about 2 years ago it hasn't seen the road yet until I get this thing finely tuned and brakes working. Does that popping through the carb when I press the gas pedal to the floor mean it's a carb issue or timing? I've got the timing at 2.5 before top center as specified for this year. I played it with at bumped it to 5 and it still did it. Plus it always starts easy, doesn't smoke, or ping when you press the gas.
