D
Deleted member 38009
Guest
The balancer on my '65 Barracuda 273 has rotated and must be replaced. All of the new replacement balancers available are for driver side timing marks, but mine has the passenger side pointer. This is a street driven car and not a HP application. I know I can use a piston stop and remark TDC, but I read that the driver and passenger side marks are 90 degrees apart in a TCI Rattler write-up at Summit. Can anyone confirm this? If true I would prefer to use a balancer that is marked every 90 degrees and just re-mark TDC at the 270 line. I searched the forum for this but only found one mention of this. Thanks, Bob
