rick1062
Active Member
I am working on a 1965 Barracuda. Only one dash light is working and it is not consistant. It is pretty hard to get behind the cluster and see what is going on. How many bulbs should there be for the gauge cluster?
What is the best way to get to them for replacement.
Secondly, the dashilght dimmer in the headlight switch seems to be erratic. When I turn it, the one dash light that is working either doesn't change or sometimes when I turn it toward brighter, the light gets dimmer. The dimmer seems to not be working right. Is there anyway to cleanup that part of the switch to get it working properly?
Thanks as always,
Rick
Thanks as always,
Rick
