Damn. Too bad it is so far away.
This one's a bit closer to ya, 65barracudadude. Not mine, either. Wish I could pick it up:
http://sfbay.craigslist.org/sby/cto/1086818392.html
for sale: 2 1965 barracudas, 1 formula s and 1 273 2 barrel car.
The Formula S is an original california car with black plates, build sheet and fender tag. Light blue exterior with black interior. 273 4 barrel with 904 auto trans. Has original tach, sway bar, heavy duty torsion bars and leaf springs, notched rear valance, etc. Rusty body.
2 Barrel car is very clean. I was starting to swap over the parts from the Formula S onto this shell but no longer have the time for this project.
Also included is a fresh 318 engine (mopar purple shaft cam (.450/.455 lift, 268/276 dur) degreed in @ 108 intake centerline, oil pump, bearings, timing chain, valve springs), exhaust manifolds have been blasted and coated with hi temp cast iron finish. Commando valve covers have been stripped and repainted wrinkle black. The correct 4 barrel air cleaner and carb are also included. Engine is sealed up, painted and ready to install.
