Work on my gasser engine swap has started.....yipee! Had the 1956 Dodge hemi gone through by Koffels Place in MI. They did all the good stuff; balanced, bored, crank turned, rods reconned, new pistons, etc.
While that was going on, we pulled the brand X engine out of the car and now have a wide open engine bay. First thing was to completely remove the old engine mounts and clean up the frame rails. The straight axle front end really opens up the space available for the little hemi and that is good!
The first pics show the bare block bolted up to the Hot Heads trans adaptor and just sitting in the car so we can size it all up and check for "apparent" issues. We'll start building the new motor mounts next and once the motor is set put on a HEMI head and fab up the headers.
So my plan is to keep you all updated on the engine install and mods and the building of the short block as we progress through assembly. Hopefully I don't get too excited and forget to take pics as we progress!
Now if I can only get the pics to load!!:banghead:
