[WANTED] 65 cuda rear end and msc
Tooljunkie
King of cobble/master of the broken bolt
Manitoba
Search for rear end,rad,4bbl intake for 82' 318 small block. 1965 Barracuda.
Looking for a parts source in Manitoba, know of a few but not getting any calls returned. Building a driver not a racer. Thanks in advance.
For rear ends your choices are the commonly found 63-later A Body with small and 73-76 large bolt pattern 7.25s, the 65-72 SBP 8.75s and the 73-76 LBP 8.25s. 65 small block 4 barrel intakes are not too common plus the use smaller mounting bolts/different bolt angle with the stock heads. Change the heads to 66-up, then you can use just about any LA 4 barrel intake. Good luck on your search!
Thanks for the info, my Teen is a 82 year, give or take.
Hopefully someone local will chime in. Thanks for posting.
