[WANTED] 65 DART ABODY GAS PEDAL AND FLOOR BRACKETS
willypete67
ky
Rating - 0%
0   0   0
I need gas pedal and floor bracket assembly for my 65 dart. Mine was rusted otu and I cant remeber how it even mounted ot the floor. Does anyone know or have some pictures of how it attached to the floor?
Is this for a slant? If so I can get you photos from a 66 Valiant which should be the same thing. I believe the slants came with the rotating rod business, while a V-8 got a throttle cable.
All there is to support the gas pedal is a piece of metal appropriately 1/8th inch thick about 2 inches long by about an inch to 1.5 inches wide with the 2 mounting holes in it spot welded to the underside of the floor pan. I removed the rusty floorpan metal from mine, cleaned up the pedal brace, determined where it needed to go and welded it to the underside before I welded the new pan in place. Slant and V8 pedals used the same floor bracket to support the pedal.
I have a 66 cuda parts car, prob the same I will get pics.
66 Cuda
