65 Dart Cable Help!
salinasjoel
Learning Daily
Indianapolis, IN
Hey guys. My service manual has a diagram but it is not at all clear, and looking at my heater box under the dash I cannot figure it out.
Where does the temp control cable go to on the heater box? Can someone post a pic? My heat/defrost cable and blower speed are hooked up but my temp control came unhooked and I cannot figure it out.
Thanks
Joel
These any help?
Top two are out of 65 manuals, bottom one is 66 Dart
perfect thanks. so if i am seeing it right there should be a door that allows outside are to mix with heated air to control the temp? if that is the case i'm going to have to fab a door and spring system as mine was missing from the car.
