'65 Dart sat too long by previous owners. Did run but then stopped. Did some investigation. Discovered bad gas in tank and tank got rusty. Have now replaced tank, sending unit and fuel line from tank to fuel pump. Connected everything back up, I think. Gas to carb but no start.
So one thing I want to check. Which way does this needle on this one barrel Holley carb go?
I took the fitting off between the carb and the fuel line earlier checking for any filters/screens. When I took the fitting off the needle fell out. Since I wasn't expecting anything to come out I didn't notice which way it should go back in! Any ideas which way the needle should go back in? The 'sharp' end facing the fuel line? Or the carb? See last two pictures for choice. In the pictures the carb would be to the right side of the fitting and the fuel line coming in from the left side.
Glenn
Glenn
