The exterior lights, cigar lighter, door jamb switches/dome light, wipers all work on my 65 Valiant. No lights on the dash cluster light up nor the oil light or transmission indicator light. The turn signal indicator lights up when you use the turn signal. There's a new engine/forward light harness under the hood so doubtful it's in there even though the oil light bulb doesn't light up. I had to replace the dash harness from a donor 65 Valiant because the original was burned out. The fuel gauge and alt gauge work. They're a small amount of surface rust on the contact where the instrument panel fuse goes. That's the only idea I could have. The harness is pretty simple and there is no breaks anywhere. The plug on the back of the gauge cluster is pushed in all the way. It's probably a ground problem. But where is the common ground for the dash lights, radio, and oil light. I think the oil light might be a separate circuit but not sure. I know the dash lights, transmission indicator, and radio all plug into the same fuse.
