65 Plymouth Valiant Parking Brake cable question
85glht
CT.
So, I know I need a front cable as the one I have is broke. The car has 2 new rear cables and it came with a new intermediate cable in the box.... What I do not have is the intermediate cable adjusting rod or connection clips. Can anyone point me in the right direction as to where I can procure these items... I've seen the connection clips BUT I have yet to find the elusive adjusting rod... Any help will be greatly appreciated!!
Thanks!!
Don’t know if I’ve seen the parts sold separately, I just bought this kit from in-line tube. I’m about to pull all the old E brake stuff from my 65 dart
Obviously this is not how the cable installs but you can see the the threads that install toward the rear. Do you have a picture of the clips you need?
I bought the complete kit, and it is now installed and working!! I had to move the front cable around to get it to go above the frame ties that I installed. also had to add a section of threaded rod to make the front cable longer due to me moving its location. I'm glad it is done and functioning. Now, on to the transmission fluid leaks :rolleyes:
I’d love to see some pictures if you don’t mind. I’m about to install my kit, and I also have frame connectors to install. I was curious as to how that was gonna work with the fuel line and the emergency brake running directly in the way in certain areas.
Sure. I'll do it later... I have no pics on the work computer :rolleyes:
You can see in the pic, the new hole that I drilled for a higher placement of the front parking cable. Then you can also see the coupler I had used to make the threaded rod a little longer.
I hope this helps.
Good job .
Do you know how many guys ordered a new front cable cuz a coupla inches of thread were missing, insteada a few inches of "ready-rod" and the "long" nut.
Congrats, - you're a true hottrodder !
Good job .
I appreciate your comment!! :thumbsup:
