Marcus V.
Marcus and Justin V. Father and son
Hello, I recently got our engine from the machine shop, 65’, 273. The crank was not useable. I had a crank from a 85’ 318, that was already turned and ready for use on the shelf. My question is this, can I still use the 65’ 904 trans with the newer converter. I understand the register in the 85’ crank is bigger, just wanting to know if this converter will work?
Thanks, Marcus and Justin
