66/67 Steering Wheel Restoration
Jim Kueneman
Sonoita, Az
I know not everyone follows my 66 Valiant thread so I thought I’d post it here and help other people who would like to restore their wheels this is how I did it.
I don’t think I could’ve asked for this steering wheel to come out any better. For those who said I should just go buy a new wheel I don’t know how you get any better than these classic original parts.  it was worth every agonizing hour.
Here’s a quick step-by-step. I used a Dremel tool to open up all cracks and tried to undercut them so that when I packed them with epoxy it would go underneath the lip to grab so that it would lock it in. Then wiped it down with generous amounts of acetone to clean it and soften the original material. Then mix up PC 7 epoxy and work it in to all the cracks and grooves. Let it dry then shape it with 80 grit sandpaper. I put it in the oven and baked it at 180. That’s because here in Arizona it can get that hot in the car. That opened up a few more cracks which I repeated the above process once I got it shaped I sprayed it was three or four coats of epoxy primer.. Once that was sanded down and I had the shape know this could easily take two or three steps repeating spraying the epoxy primer and sanding. Once I got it shaped the way I wanted I took a hobby razor saw with coarse teeth and just dragged it around the wheel putting deep grooves in it to simulate wood grain. After that I used artists acrylic paints raw umber and burnt ombre mixed with a little water to make a wash. Before that I overcoated the epoxy primer with SEM palomino rattle can paint to give it a light tan base coat.. I then washed on the acrylics and wipe them off carefully to get the shading that I wanted. once happy with that I had some India ink that I probably mix 10% ink with 90% rubbing alcohol to make a black wash which I then spread around the wheel to highlight the grooves carefully wiping off the excess so that it didn’t pool and leave a black ring. Then two coats of universal clear let it dry sand it was 500 grit sandpaper and two more coats of universal clear..
Capital Metal Finishing in Tucson did the chrome work. I drilled out all the mushroom pins to completely disassemble the wheel and allow capital to restore each piece individually to put it together all I did was drill and tap number 6-32 screws and used machine screws to reassemble it
Dang Jim that’s killer! Excellent work my friend :thumbsup:
Nice job! Is your car a real early '66? The door panels and horn button are like the '65 Barracuda models. My early '66 had that horn button too. I don't know on the door panels, as when I bought it 40+ years ago, it had custom tuck and roll door panels....yuk!:eek:
Nice eye... those are '65 panels because they were reasonably priced and available :). The wheel is out of a '66 Valiant 200 4 door that I got the AC system out so I snagged the column while I was there.
Man this turned out sweet. I have 2 of these wheels that I need to re-do over here in Phoenix if you are ever bored…
Super nice Sir!! That takes some talent & lots of patience!
