pyrojim
So, I'm laying out the harness and have a couple questions.
#1. Radio, it shows connections on the wiring diagram, but tey are not incorporated into the new harness?? Do I make my own and wire it as per the diagram??
#2. The diagram shows for turn signal flasher (red and black) but I seem to have an extra connector that looks the same? (red and yellow)? Emergency flasher???
#3. Ignition switch has 6 pins but the harness only has 5?? leaving one connector open?? Is there a purpose for this? Diagram shows switch with only 5 connectors???
Thanks for your help!
Jim
Jim
