OK, so I have a 66 dart with a slant six thats in surprisingly good condition, but I find myself shying away from driving it because of the antiquated braking system. It has four wheel drum brakes, which doesn't bother me, but the master cylinder is a single reservoir type, and that bothers me in a big way.
I would like to go to a dual reservoir master cylinder, so in the event of a failure...... I don't die
Here's the info I need;
1- which master cylinder can I use(for what vehicle).
2- do I need a proportioning valve? I'm assuming no, since its a disc brake part?
3- what do I need other than new plumbing. Junction block of some type I'm thinking
4- the wheel cylinders on this car are seized from sitting. I want to order new cylinders for the car but I can't remember if it has 9" or 10" drums. The 10" has the bigger piston and I'm going to order it for the extra breaking power. Chances are they bolt up the same way right?
