Ryan Hoelzer
Troubleshooting non working speedometer, I found that the cable isn't spinning, but I can pull it all the way out and it's intact, and when I push it back in I have to turn it to get it to drop in the other end. And then I can't turn it by hand. So it seems like it's in place on the transmission end. I believe there is some plastic gearing under the cover on the transmission end? Assuming something is locked up or broken there? Am I going to lose fluid removing that cover?
