vitamindart
so im going to be replacing the radiator in my valiant.
when I do that should I replace the old cast iron water pump with the newer style?
its a cruiser and my concern is the older cast iron water pump wont be readily available in a pinch. will I be able to use my current alternator bracket & pulleys?
figure now is the time to change this as I believe the outlet is on the other side.
